07-25-2005 04:00 PM
07-25-2005 04:23 PM
07-26-2005 10:49 AM
07-26-2005 03:48 PM
I got it working. Thanks for you input. I believe I simply was missing a command on the command line (it takes about 5 parameters). It was falling through and I wasn't able to catch what was going on. I thought it was a thread issue within teststand that I needed to set. I also didn't realize the default location that it executes from any my paths were explicit. I also wasn't clear on some other details but have now figured them out pretty much.
Thanks again
Jim
Are you using the call executable step type? If so please provide more informations about how you have it configured, if not please explain what you are doing. By DOS executeable do you mean an old 8-bit DOS program (what version of windows are you running this on?)? Or do you mean a windows console application? Are you getting any error messages? How are you verifying that your executeable isn't being called? Or is the problem just with the IO redirection?
-Doug
