02-01-2007 07:53 AM
02-05-2007 09:39 AM
02-06-2007 02:00 AM
Hi Sarah
The 1102C modules are ones we have had for quite sometime now. The Daq card I used calibrated OK with the 'Calibration Executive programme. I must admit that I have not tried another Daq card or PC. Hope this information is enough for a start to the diagnosis of my problem.
Cheers
Herbie
02-06-2007 04:26 AM
Hi Herbie,
Are you confident your SCXI modules are working? Have you run the self test in MAX on them? Are the reading values as expected? Have you any other SCXI modules you could test in the system?
Were all the SCXI modules that failed being used in the same system? Could they have been exposed to some high voltages that damaged them? Have you checked that they haven't been set up to measure current (this is done by installing shunt resisstors)?
02-06-2007 04:58 AM
Hi Sarah
I have tried five different 1102C modules. The first module passed but subsequent 1102C modules started failing on the -98mV range (a reading of approx -8.5V on the DMM). I re-tested the first module but this also failed for the same reason. I changed the various components of my system with no improvement; I then calibrated the PCI 6034E Daq card: no problems. Does this throw any light onto the subject?
Cheers
Herbie
02-06-2007 10:28 AM
Hi Herbie,
I'm going to ask one of the engineers in the US to have a look at this. I would be surprised if this was an issue with your software but I want to check before I ask you to investigate you're hardware further. I will post back as soon as I hear something.
02-06-2007 10:39 AM
Hi Herbie,
Try testing your system on another machine and with another DAQ card if you can.
02-07-2007 02:00 AM
Hi Sarah
Thanks for the suggestion. I may not be able to try it out for awhile because the other PC's are being used. My machine has the software installed because it is used as the Labview development machine. I will let you know how I get on.
Herbie
02-07-2007 10:24 AM
Hi Sarah
I have tried 3 different PC's. Each time I try to start the progrmme a dalogue box appears telling me that 'an unknown error has ocurred'. At the moment my machine is the only one that will run the software. Please keep me posted if any further solutions to my problem are sent to you.
Thanks again
Herbie
02-08-2007 06:59 AM
