NI TestStand
automation interface for specified class cannot be obtained
I am trying to use a TestStand UI Expression Edit Control in LabVIEW to undertake an Expression.Evaluation, but I feel I must be missing something. I have a TestStand UI ExpressionEdit Control on the LabVIEW front panel, and when i try to evaluate it, or anything else (properties or methods) for that matter, the error is always the same:
"Automation Interface for the specified class cannot be obtained. Check if the automation refnum type is the correct class for this operation" Error Code 3008; User defined error code.
Any help tips or pointers would be appreciated.
(4,016 Views)
Hi
To help resolve this issue can you post the VI which gives you this error.
Regards
Anand Jain
National Instruments.
(4,007 Views)
Hi Anand,
I am using activex object ref to access canalyzer and open a configuration file i wanted. That is what i am trying to do it here.
I am also facing the same issue. I am posting my vi here. Can you explain me what i am missing over here.
Thank You.
Raghavendra.
(3,019 Views)
