03-27-2013 02:31 PM
I would like to log the output of a "flatten to xml" vi and display it in a tabular format in my Teststand xml report. I'm wondering if anyone has a starting point for the stylesheet side of things.
03-28-2013 09:41 AM - edited 03-28-2013 09:42 AM
Hi kwkengineer,
The best starting would probably this article on customizing the syle sheet. You can find it here
http://digital.ni.com/public.nsf/allkb/EC64D7C24421A2E58625751D00491809?OpenDocument
It gives some good pointers and documentation on how to customize the style sheet for your xml based report.
Also, we have an article on best practices for styling found here
http://www.ni.com/white-paper/8289/en
If you have any further questions or are in need of more information do not hesitate to ask.
03-28-2013 11:47 AM
Almost there....
I have a properly formated XML string from Labview to Teststand. I have the XSL which has been tested and added to my horizontal.xsl used by the Teststand report. My problem now is that when I log the XML string using Additional Results, Teststand is putting the CDATA tag around the string preventing it from using my XSL. Is there a flag or something to set so Teststand will add the XML as is.
I've done this before using the ModifyReportHeader callback and the GetXML method, but the ModifyReportEntry doesn't work for XML reports. So I really need to know how to stick my XML in the report from my client sequence file without Teststand altering it.
Kevin
03-29-2013 10:49 AM
Hi Kevin,
Depending on the version of TestStand you are using, the best approach may to actually go in and override the TestReport callback. TestStand 2012 ends up calling NI_ReportGenerator.seq and add the actual xml string to the body results. Is that an approach you have looked at?
03-29-2013 03:05 PM
I've thought about that, but haven't tried yet. For the time being I'm just writing the xml to a separate file. My internal customer might end up liking it better that way .
