I'm working with a customized version of the Simple OI (labview). I have tracing set in TS so that it doesn't trace into the setup and cleanup steps, because once the test has finished I want the operator to be able to see the list of tests and their results in the execution view (I don't want them to have to look into the report). If I were to allow tracing, they would be left seeing only the cleanup steps.
My problem is that the setup step in the sequences I am running can take a few seconds to execute, and it might be confusing to operators that the test does not start immediately. I want to give them some visual indication that something is happening. What is the best way to do this? Is there a way to allow the tracing, and at the end of the execution return the view to the "main" portion? Or is there a way to concatenate setup,main and cleanup into one list in the execution view? Or should I implement a pop-up box at the start of the test that says "Initializing..." (and how would I do that)?
Thanks for any help!
