01-13-2015 03:32 AM
Hello All.
I am trying to integrate the android Debug Tool (adb) and Monkeyrunner with Teststand. I am quite new to Teststand, and I am unable to figure out how to use external programs and tools in teststand. Would be cool if someone can give me pointers on setting up adb with Teststand.
Thanks.
Harish
Solved! Go to Solution.
01-14-2015 04:55 AM
Hey Harish,
it would be helpful for me, if you can descripe the purpose of the android Debug Tool (adb) and Monkeyrunner.
I'm (and most of the TestStand-Fourm users) know something about TestStand, but nothing about both tools.
What do you want to accomplish?
How do you want to use this external tools? Like a Command Line tool? ActiveX-Integration?
Regards, Stephan
01-14-2015 06:42 AM
Dear Stephan,
adb along with monkeyrunner is an API for writing script programs to control an android device. Its possible to write some python scripts that can be run via the Monkeyrunner tool which is a commandline tool to test certain packages. I am trying to integrate this with teststand so that i can migrate the already written python scripts directly to teststand and generate results based on the results.
Thanks.
Harish
01-14-2015 09:16 AM
Hi Harish,
do you need something like that:
Calling Scripting Languages from NI TestStand - National Instruments
http://www.ni.com/white-paper/8847/en/
Call already existing python scripts directly from TestStand ?
01-15-2015 08:54 AM
Thanks stephan ... that whitepaper is very useful. I just have to figure out myself about obtaining the outputs to a variable for post processing with teststand.
Thanks.
harish
09-10-2015 06:35 AM
Hi Haresh - I was wondering how you are coming along with your TestStand Android integration. Ideally I would like to see a library developed that would allow testStand to directly communicate with an Instrumented Android App so that the script could interact with the Android UI for White box testing.
