I am having troubles referencing a property of a custom SequenceCall step I created. The idea is to add a field to the SequenceCall that I can populate with a Post Expression and then filter out this SequenceCall if it matches a certain string.
I have attached a screen shot that should clarify things more. What it shows is that when looking at the XML source (left) the standard property "ReportText" is inside the same "TEResult" container as my new "Profile" property. This structure similarity is reinforced by the TestStand display of the newly created "Clemente_SequenceCall" (upper right). However, when I try to access the text of "Profile" the entire body of the report does not render due to an error somewhere above the "CheckIfStepSatisfiesFilteringCondition()" function. What is strange is that I can access the text of "ReportText" just fine and perform checks against it to filter out a sequence call. The two properties and lines of code are so similar that I am stumped as to what I am missing.
Since this is a custom property that not all steps have, do I need to first check if the Profile property exists? Unfortunately I have no idea how to do this. I have a feeling that it somehow relies on the "typeof" operand in javascript, but my initial attempts to compare it to "undefined" did not work...
Any help is greatly appreciated. Thank you.
