03-27-2006 08:16 AM
We are using the XML On The Fly report generation option to show the measurement data to our operators while they are testing the products.
But we have experienced that this option isn’t updating the report field in the TestStand Editor or OI correctly during execution when a sub seq. is calling a sub seq (not a abnormal situation).
It looks like that the “ProcessOTFStepResult” in “reportgen_xml.seq” can’t add the “StepResultBody” to the “ResultBody” when the call stack exceed 3 levels.
Is this an Option (adjustable), Limitation or a bug? Is there a solution to this problem?
I have attached an example that show the problem. It’s made in TS 3.1 but the problem is also seen in 3.5. Run it with the sequential model. It shows a dialog in each level of sub sequences, so it’s possible to follow the OTF report generation in the report tab. In the end (when the call stack is increased again all the report items is updated correctly.)
I´m looking forward to hear from you.
Best Regards,
Morten Pedersen
CIM Industrial Systems A/S
