Hello.
i´m using TS3.5 and LV 8.2.
In a sequence are steps called and some of the steps are failed. Now i´m wondering why the sequence is still passed?
I checked all steps for the flag Properties ->RunOptions-> "Step failure causes sequence failure" : Its enabled everywhere.
Are there other things what i can check why this is so?
The RunMode of the sequence is "Normal" (not force Pass).
The steps are numeric-limit-tests. The fail because the result is not in the limit.
Thanks for your ideas
