NI Home
Cart Cart | Help
You are here:
Reply
Member
lv4ever
Accepted Solution
Where to set "DataLayout" (2D data in report)?
Im using Teststand 2010 SP1 and Labview 2011. My question is about plotting 2d-array data into the Teststand HTML report.
I try to retrieve a 2D array with x-y data of measurement and to plot it within the report file. Unfortuntly the data is interpreted as "multiple-Y" which means each x-y pair generates a new curve in the plot instead of having one curve following the x-y pairs. I found the following in TS documentation:
http://zone.ni.com/reference/en-XX/help/370052J-01/tsref/infotopics/measurement_data/
The problem is: I do not know WHERE to set the property objects attributes. Has someone an running code snippet as example setting the attributes at the right point and generating a x-y-plot correctly?
Thanks for help in advance.
lv4ever
Member
mkais
Re: Where to set "DataLayout" (2D data in report)?
You can log a 2D Array to a Teststand Result Database and export this result to a Report as HTML.
http://digital.ni.com/public.nsf/allkb/1307679F845B162286257160000510ED?OpenDocument
You can also Create HTML table from LabVIEW array and use it in Teststand
https://decibel.ni.com/content/docs/DOC-5552
Only Some of the Elements in Large 3D Boolean Array Are Filled in TestStand 1.0.2
http://digital.ni.com/public.nsf/allkb/6CD5056EFB198972C1256B870064AB42?OpenDocument
Kais Mekacher
Applications Engineer
Germany - Munich
Active Participant
Anand_Jain
Follow the following link to learn how to create attributes in TestStand - PropertyObject Attributes
Anand Jain
Member
lv4ever
Thanks for replays - but they are answering not my question.
@mkin75: I have realized thats possible to customize the reports with effort in many ways. But I expected Teststand to have such a very basic test sequencer function to have it build in. And as I understood the manuals it is build in.
@Anand Jain
I understood that a have to add a property object attribute and how is also clear to me. The question is again where is the property object "Teststand.DataLayout" to be added?
I tried to add to
- the testsequence
- to the test step which retrieves the xy-data
-the paramter which gets the xy-data
None of this resulted in the required plot appearence.
That was the reason I ask for a running example. For convience I have added my effectless tries.
lv4ever
Active Participant
Anand_Jain
lv4ever,
I reviewed the documentation and I agree that it is not clear where the attributes should be added. I will write a bug report to fix this issue.
The recommended approach for you is to create local variables that have the approriate attribute and use these local variables in the value expresions for each parameter.
I have attached an updated files with the proposed solution.
Anand Jain
Member
lv4ever
Thanks, that was what I looked for. I appriciate your support very much.:smileyhappy:
Member
R.Arnold
[ Edited ]
I guess there might be something that needs to be configured.
I'm trying exactly the same (X-Y graph form 2d-array), but Attributes are not affecting my output.
I created a very simple test file, with a defined array with fixed values. Added the attributes Datalayout/Dataorientation.
The attached example earlier in this thread is also not working for me.
Any ideas what I'm doing wrong?
Active Participant
Anand_Jain
I am able to create a 2D graph using the files you attahced.See attached JPEG.
Can you please attach files that you are using that exhibit the problem.
Anand Jain
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
