NI TestStand
When does switching occour when executing a step?
I'm trying to figure out when switching occours in the order of execution of a step.
The TestStand 3.1 Manual (Table 3-4) does not apper to have been updated to include this information.
I'm trying to evaluate routes at runtime (based on the RunState.TestSocket.MyIndex).
It appears that switching occours before the Pre-Expression or Pre-Substep is executed. Is this correct?
Simon Holman
Simon Holman
Software Engineer
Certified LabVIEW Developer
Certified TestStand Developer
measX GmbH & Co. KG.
http://www.measx.com
(3,094 Views)
Howdy Simon -
I see where your concern lies.  I am also unsure off the top of my head where the switching execution order is when the switching is being specified from the step properties dialog box.  I will check into that further, and let you know exactly where the execution points are.
As one possible alternative, you could specify your switching through expressions.  You could then be sure that the switching is executed in the pre and post-expression execution points.  To do this, on a step which requires switching, right-click and go to properties.  Under the Expressions tab, click on the Expression browser button for any of the expressions.  You can find the switching functions under the Operators/Functions tab.
I'll let you know what I find.  Have a great day!
Andrew  W || Applications Engineer
(3,072 Views)
Simon -
Yes, the step switching is initiated after (6) "Load module if not already loaded" and before (7) in Table 3-4.
Scott Richardson
(3,065 Views)
Thanks Scott
Simon Holman
Software Engineer
(3,052 Views)
