It seems to want to match with a type Locals.ECIData type instead of a type ECIData. An error -17311 is generated. you cannot make a type of type Locals.ECIData, so it shouldn't be trying to match for one. Also switching of the type checking doesn't make any difference, it still errors.
Have you tried passing your local via the Parameters of the sub-Sequence and then pick up the variable Parameters.ECIData on your LabView connector pane.
I have attached a small TS3 and LV7 example. This does get picked up by the VI.:)
Regards
Ray Farmer
Regards
Ray Farmer
