09-08-2006 01:42 AM
09-08-2006 04:10 PM - edited 09-08-2006 04:10 PM
Howdy Rajesh,
Since you are a beginner in TestStand you don't want to get
far ahead of yourself as there is a lot of features in TestStand that if you
jump into to soon can be confusing.
I would strongly suggest taking our TestStand I && II course as they
will make your TestStand journey much easier. I would also recommend
walking through our TestStand Reference Manual
(Help >> Search the TestStand Bookshelf; Notice a bunch of reference
guides) which contains answers to a bunch of beginner questions such as the one
you are asking and takes you through TestStand basics and some advanced
features. In particular, Chapter 14
entitle "Standard and Custom Data Types" discusses your questions.
As an overview of what you will be reading in terms of your
questions, TestStand contains sequences that contains local variables. Sequences
can have any number of local variables, which you can use to hold values that
you get or set in step modules. You can also use local variables for
maintaining counts, for holding intermediate values, or any other purpose.
One of those local variables is an Object Reference
that contains a reference to a .NET or ActiveX/COM object. It can be equated to
pointers in most programming languages.
When you are in the locals tab, you can right-click and
select Insert Local which contains a submenu from which you
select the data type for the local variable you want to insert. If you
want to insert a local variable with a custom data type, you must create a
named data type. You can create a named data type in the Sequence File types view of the Sequence File window or in the Types Palette window.
After you create the named data type, it appears in the Types submenu of the
Insert Local submenu. Some of these types you see are used by step types
such as path or expression. For example, open a new sequence file and drop down
and Expression Statement step. Then select the View drop-down ring
control and choose Sequence File types. Then select the Standard Data
Types tab and notice Path and Expression are listed as they are part of the
step you inserted into your sequence.
I would definitely recommend looking at our TestStand
Developer Zone for reference as it has examples and tutorials that are
extremely helpful.
Again, talking about step types and custom data types is a
little more advanced than the stage you are at. So start at the basics and work
your way up.
Hope this helps!
Best Regards,
Message Edited by Jonathan N on 09-08-2006 04:12 PM
