Hello dear Experts,
I am using LABView 7.1 and Teststand 3.1
I am having a problem on Teststand. This what happended:
1.On SEQUENCE FILE WINDOW,I inserted step, choose ACTION.
2.On my right click on the icon, I choose SPECIFY MODULE.
3."Edit LABView VI Call" window appears. When I choose "niSwitch Initialize.vi" here is the pop-up
"LabVIEW : LabVIEW: VI Server access denied.
The VI could not be loaded.
It is possible that the active LabVIEW version is not 7.0 or greater.
Also, you can select a version of the LabVIEW Run-Time Engine to load the VIs in the adapter configuration dialog.
Error Code: -18002, LabVIEW reported an error."
Dear experts, I've already tried "LabVIEW" in the adapter configuration, but still don't work.
Hoping for your prompt response.
Thank you and MABUHAY!
Ryan A. Bilaos, ECE
Manila
