09-16-2013 05:56 AM
As in subject: what is an advantage of project path in Step properties (LV adapter)?
09-16-2013 06:09 AM
You should get familiar with the term "application instance" in LV. With this knowledge, you should be able to answer this question on your own.
hope it helps,
Norbert
09-16-2013 07:21 AM
Can't see any connection between 'application instance' and value added by specifying the project path there
09-16-2013 07:35 AM
Well, when defining a project to the adapter, you assign a specific application instance.
Simple as that, nothing more.
Norbert
09-16-2013 07:37 AM
But for what?
Usualy I connect VI directly or thru llb.
09-16-2013 07:53 AM
As i said, you should learn about "application instances" in LV.
One hint:
LV internal communication channels (e.g. Queue, FGV) are only valid within a single application instance.....
Norbert
09-16-2013 02:15 PM
Hi all,
The following document provides more detail on LabVIEW Application instances and how they relate to TestStand.
How TestStand Interacts with LabVIEW Application Instances
Hope this helps clarify things!
03-24-2020 03:57 PM
unless you need those 'application instance' advantages called out below I would advise not using the project path if you later intend to switch from LV DEV to LV RTE. You will have to re-do those paths at that point and I'm now finding that alot of times TS 2019 is re-populating the Project path instead of letting me browse to a absolute path straight to the VI. not fun
