08-31-2007 12:42 PM
09-04-2007 09:14 AM
Vidula -
The message states that the TestStand readme has more information, and it states the following:
The TestStandApplications that create and destroy the Microsoft Internet Explorer (IE) control might leak GDI memory, making the application and the computer unstable. The memory leak occurs when you run the application on Windows XP Service Pack 2 and you installed the Handwriting feature (version 1.0.1038 of the
Skchui.dll
file) for a Microsoft Office product on the computer. For TestStand, the sequence editor creates new instances of the IE control for each new execution document, and each ReportView User Interface control creates a new instance of the IE control. To prevent this GDI memory leak, uninstall the Handwriting feature for any Microsoft Office product and for any other product that uses this shared feature. Refer to the Microsoft Knowledge Base Article 896429, located at http://support.microsoft.com/default.aspx?scid=kb;en-us;896429, for more information about this issue.
Hope this helps...
11-12-2007 11:18 AM
11-12-2007 11:22 AM
This worked for me try it, see if it works for you:
Open TestStand, and go to Configure->Station Options, click the Preferences tab, then click the "Debug Options..." button at the bottom. This will open the Debug Options window where you can uncheck the Report Object Leaks option.
Vidula
11-12-2007 12:18 PM
11-12-2007 10:59 PM - edited 11-12-2007 11:02 PM
11-14-2007 10:15 AM
12-04-2007 12:10 PM
I deleted the file, and the next time I opened Word, it ran the installer and re-installed the file. The solution in the microsoft knowledgebase does me no good either. Any other ideas on how to get rid of this?
Thanks!
12-05-2007 10:24 PM
12-06-2007 09:13 AM
