07-28-2006 07:43 AM
07-31-2006 09:51 AM
Hi checkers18,
I was able to replicate the behavior you saw of the VI not positioning correctly. I did discover as well that it was not an issue with TestStand but rather LabVIEW itself. The VI works fine under these scenarios in LabVIEW:
- If VI is non-reentrant, it always works
- If VI is reentrant and is called as a top-level VI
The VI doesn't work if the VI is reentrant and is called as a subVI.
I have filed this as a bug. Thanks for the find!
Best Regards,
09-11-2006 01:38 AM
i have a similar problem with showing two vi frontpanels in TS. Iám using the FP.Runtimeposition.Userdefine to change the position of frontpanel 2. But at the first start of this vi it is displayed at the default position (above frontpanel 1). At the second start it appears at the wanted position. How can i tell the vi to appear at the first start at the wanted position?
regards
Schwede
09-11-2006 05:09 PM
09-12-2006 12:42 AM
I think it is a LV programming problem. At the first start of the vi it doesn`t know the position that i want and open the frontpanel at the default position. In the LV code i ask the vi to show (move?) the frontpanel at the wanted position. But the frontpanel do this not immediatley but at the next start of the vi.
Have I used the wrong code?
regards
Schwede
