I can go to MAX and select Software. Below the selection is all my applications with their associated versions. Is there a place, possibly the registry that lists the application and version that I can copy and paste into a text editor?
All of the National Instruments Software information can be found in the Registry Editor. From there, you can copy the information and paste it into a text document. Launch the Registry Editor by browsing to Start >> Run and typing regedit in the window and then hit enter. Then once you are inside the Registry editor, browse HKEY_LOCAL_MACHINE >> SOFTWARE >> National Instruments. Browse through the folders and double-click on a key. Then copy and paste that text in a text editor.
