05-27-2017 11:07 PM
Need to pass variable from Teststand to Scapy python script and build the packet in one step. http: Ether()/IP(dst=server)/TCP(dport=80)/"GET /index.html HTTP/1.0"
#!/usr/bin/env python import sys
Ether()/IP(dst=argv[0])/TCP(dport=argv[1])/argv[2]"
using sys.argv[n], is correct?
05-28-2017 12:25 AM
I am using customized type to send parameter to python script. How to pass testStand parameter. is using sys.argv correct?
#! /usr/bin/env python
from scapy.all import send, IP, ICMP
#send(IP(src="10.0.99.100",dst="10.1.99.100")/ICMP()/"Hello World")
send(IP(src=sys.argv[0],dst=sys.argv[1])/ICMP()/argv[2])
