NI TestStand
VB .NET Teststand memory leak
I got a memory leak problem when I try to read an array with Teststand from a Visual Basic application.
My application reads a string array several times per seconds.  To read this array, I create (in TS) a local string array of 4 elements (array[0...3]).  This array is linked with the return value of my VB function.  When I run this application I got a memory leak.  I attached an example (see the "Memory Leak Occured").  Can you help me on that issue?
I found another way to do the same thing and no memory leak occured but it's painful to program.  See the "No Memory Leak" in the attached example.
I use Teststand 3.5.0.725.
Simon
(3,197 Views)
Here is the attached file.
(3,195 Views)
Could someone try this application just to know if you'll get the same problem?
Simon
(3,158 Views)
Hi tm4,
I believe you sent an email as well. I just replied to your latest email as we did replicate the memory leak here. We are looking into this issue.
Best Regards,
Jonathan N.
(3,146 Views)
