Using labview global in test stand sequence steps
If I have to pass data between different steps ( only labview vis) within same Main sequence, is it right using LabVIEW globals, rather than TestStand globals?
in one step, I will be writing data to the Global.
In a later step, I will be reading the global to access that data.
Example sequence:
I am more comfortable with using Labview globals than Teststand variables. Labview is the only adapter in my sequence.
(4,931 Views)
If it is just within one sequence, then I would use the TestStand variables.  The reason is because you are limiting your possible reuse of those VIs by using the global.  If you pass in the value, you have a better chance of being able to reuse the VI.
GCentral
(4,914 Views)
In some perspective, yes, it would limit the reusability.
But in a case, where this global has to be used in a " write once -read many time" way, I feel that it is easier with Labview global. If we use TestStand variable, every time this vi is called in a step, we have to connect the variable to the vi input terminal (which I find a little time consuming, to open the variable browser and selec the variable).
Also I want to know if there is any peformance/efficiency difference in the execution.
(4,910 Views)
I agree with
If you are going to use globals, I would suggest the use of a functional global variable (FGV).  This can be called from both the TestStand sequence (LabVIEW Adapter Step) or a VI.  If you are only using the global within LabVIEW, I would believe the performance would be faster than passing from TestStand.
CLA, CTA
(4,895 Views)
Thanks for the info..
(4,868 Views)
