NI TestStand
Using Enums containing spaces in expressions in TestStand 2016
Hi, just upgraded to TestStand 2016f1 today. Smiley Happy
So I created a typdef Enum in LabVIEW.  The enum had mutlple words with spaces for a value.
I then called the VI from the teststand adpator and clicked the Create/Update Custom Date Type from Enum button.
All good so far.  But now I want to use the enum in the expression.
Locals.myEnumVal==Enums.myEnumName.firstword secondword
I get an unexpected token syntax error on secondword.
If I look at http://www.ni.com/white-paper/52330/en/#toc3 I note it has quotes in the value column, where my enum has a value of
[firstword secondword] (0)
where (0) is the enum constant.
How is this supposed to work? I can't find an example. Help doesn't cover spaces. I.e no examples for a color "light blue". E.g.
locals.myFavoriteColor==Enums.Color.Light Blue
- how do we get this to work?...Smiley Frustrated I assume its something obvious I have overlooked.
http://zone.ni.com/reference/en-XX/help/370052R-01/tsfundamentals/infotopics/usingenumstsadapters/
http://zone.ni.com/reference/en-XX/help/370052R-01/tsfundamentals/infotopics/enumsastsexpressions/
http://zone.ni.com/reference/en-XX/help/370052R-01/tsfundamentals/infotopics/gettingstartedcreatinge...
Cheers.
Message 1 of 8
(5,802 Views)
Try the Enum() expession function - it's mentinoed in the help topic you linked.
Spoiler
Enum(String type, [String|Number] value) — Returns an instance of an enumeration with the specified type and value. If value is a string, the enumerator and number are set as if by calling SetValString(). Passing an out of range value results in an error. If value is a number, the value is set as if by calling SetValNumber(), SetValInteger64(), SetValUnsignedInteger64() as appropriate for the representation of the enumeration type. Passing an out of range value to a strict enumeration results in a runtime error.
Hope this helps!
Trent
https://www.linkedin.com/in/trentweaver
Message 2 of 8
(5,780 Views)
Hi Trent
thanks for your reply. I found that and still couldn't figure out what it wanted or how to make it work.
Locals.myFavoriteColor==Enum(Enum.Color,Enums.Color.light blue) still gives an unexpected token.
Locals.myFavoriteColor==Enum(Enum.Color,"Enums.Color.light blue") - could not find type ".
To me the whole point of the enum is to be able to type Enums. {Prompt for defined enum names...} . {prompt for value string}
So for the color example how to get it to work?
Message 3 of 8
(5,764 Views)
Pictures...
Message 4 of 8
(5,757 Views)
Accepted by topic author NickNZ
The Enum() method is expecting a string for the first input as well, try:
Locals.myFavoriteColor=Enum("Color","light blue")
or
Locals.myFavoriteColor=Enum("Color",3)
I understand what you mean about the auto complete issue, and there is actually already a CAR (612847) in place improve the auto complete usability for enums.
Hope this helps!
Trent
Message 5 of 8
(5,751 Views)
Thanks a lot  for your help Trent, at least I can progress now....
I tried Locals.myFavoriteColor == Enum(Enums.Color,"Dark Blue") Error is expected type String Found type (Enum) Color.
Locals.myFavoriteColor == Enum("Enums.Color","Dark Blue")  also fails as cannot find type Enums.Color.....
Lets say its not that intutive and misses the point of autocomplete alltogether. Autocomplete is currently miss-leading users down the wrong path as well.  I look forward to the CAR being completed.
Message 6 of 8
(5,741 Views)
Hello Nick,
I know you probably found an answer by now, but I wanted to give an answer in case someone else runs across this.  We have a similar situation.
I believe the code needed is
Locals.myFavoriteColor = Enum("Color","Dark Blue")
I apologize.  I see you did get the answer earlier.
Message 7 of 8
(5,171 Views)
I am using TS2017 and the same problem occurs.
Is there new workaround avaliable?
There is moe scenarios with this breaks, for example when typing
Enums.MyEnum.%s%d
Message 8 of 8
(3,879 Views)
