NI TestStand
Use of function TSUI_ApplicationMgrCloseAllSequenceFiles
I have added the following line into the source code of the operator Interface:
 tsErrChk(TSUI_ApplicationMgrCloseAllSequenceFiles (gMainWindow.applicationMgr, &errorInfo));
but no sequence file is closed.
I can see all open sequence file in the Filechoice combobox
what is the problem?
regards samuel
(2,463 Views)
You need to make sure that none of the sequence files have executions or you have references to the sequence file else where in your OI. If you have then the ApplicationManager can not release and close the sequence files.
Regards
Ray Farmer
Regards
Ray Farmer
(2,451 Views)
