NI TestStand
Updating TS container from labview
I have a labview cluster which I defined as a container in test stand. I want to update this container from labview using the set property function.I also want to create the item if not present. I see this polymorphic VI doesnt have option to choose clusters.
I tried to use the methods and properties of TS in labview. There I chose the option for variant. But here I cannot enable the option to create the variable if not found.
How can I update a container in teststand from labview? How can I create it if not present at runtime?
The attahed vi is based on the second method, where I cannot create variable in runtime?
(3,359 Views)
Hey Gops,
Unfortunately there is a not a single method you can use to directly create a container in TestStand from a LabVIEW cluster.  What you will have to do is create the container and set each subproperty individually.  I would recommend first making a custom data type for your cluster so you don't have to create each subproperty programmatically as well.  I have attached a small example that will programmatically create a copy of Locals.Original_Cluster at Locals.NewCluster.  In the example I use the Engine to create a new property object that is of the type "myCluster" (custom data type I created for the cluster).  Then I set each subelement using setvalstring, setvalboolean, and setvalnumeric.
I know you had mentioned that you needed to do this programmatically, but if it is possible, it would be much easier if you were to just pass this as a parameter of your VI.  This way TestStand will do everything for you. Hope this helps!
Pat P.
Software Engineer
(3,340 Views)
Thanks for the example, but the 'NewCluster' doesn't pop up after the VI execution.
David Koch
(2,769 Views)
