10-24-2012 08:39 AM
I am new to TestStand and am trying to get together a proof of concept for my management team. I have one sequence file with two actions that I need to run multiple times. Each iteration I need to change the input parameters and the limits expected value. Is there a way to load some sort of file, txt, xml, ect that can hold these parameters. That way when my requirements change I do not have to go in and change my values around?
BR
10-24-2012 09:10 AM
There's a step type called Property Loader. This is likely the guy you want to use.
