09-28-2016 02:44 PM
I am using Test Stand 2014SP1, In our tests, we need a custom action which creates a "Daily Summary" file of all the pass/fail reports. We do this by over riding the default DoPostUUT. Our custom DoPostUUT does 2 things.
1) calls the default DoPostUUT
2) calls a python script that parses the report file just created by the default DoPostUUT
This has worked well for us for multiple projects deployed to multiple locations. (other than normal problems with python)
Our latest error has us stumped. At the deployment site we are getting the following error:
Error calling sequence DoPostUUT.
Unknown function or sequence name "DoPostUUT".
Error code: -17320: Unknown function or sequence name.
I have not been able to reproduce this on my clean test PC, we only see it at the end user site.
Has anyone seen this before?
09-28-2016 11:34 PM
Whether both the system has has TestStand version(32bit /64bit) and also check whther your Modified DoPreUUT is Transfered to new system as well
09-29-2016 01:36 PM
Solved, Looks like it was a corrupted install. they ran the installer again and it worked fine.
Thank you for the ideas though. I was at a loss to what to check.
