05-31-2006 11:21 AM
06-01-2006 12:34 AM
This sounds like a windows issue, you probably need to speak to your IT people to ensure you have write access to at least the TestStand folder.
Ray Farmer
06-01-2006 08:24 AM
06-01-2006 09:21 AM
Vicente -
When you change the value of the Configuration Directory on the Preferences tab of the Station Options, TestStand stores this value in the Registry under the following string key: HKEY_LOCAL_MACHINE\SOFTWARE\National Instruments\TestStand\3.5\CfgLocation. Do you have authority to write to the registry? If you do not, the registry value will not be written out. If you do not enter a valid directory path, TestStand will ignore the new value on startup.
07-17-2006 02:48 AM
Hi Scott,
Vicente -
Is the location the same for Teststand 3.1 ?
I can only find ...\TestStand\3.1\UserInfo .
thanks,
Gary.
07-17-2006 03:22 AM
Whoops....sorry Scott, it's in the same place.
Sorry, it's Monday morning.
Gary.
06-11-2014 08:01 AM
I noticed a curious behavior today with TestStand 2014 Beta (haven't tested other versions): when I change the CfgLocation from the "Station Options" dialog, it gets written to the usual registry value and works fine.
However I cannot change the registry key using regedit or reg - which is no surprise as I am starting all these programs without administrative rights on Windows 7 64bit.
THe curious thing is: how can TestStand change the key without adminstrative rights?
Peter
