NI TestStand
Unable to load Labview project
Hello
I am using TestStand to run a number of Labview Tests but whenever I start to load the labview file, the following error occurs
"Unable to load LabVIEW project. The LabVIEW project or one of its dependencies might be missing. "
You can see this error in the image file attached below.
Omer Bashir
(3,911 Views)
Hello Omer,
I'm curious if you have NI 488.2 driver downloaded?
http://www.ni.com/download/ni-488.2-14.0/4802/en/
Also, I'm sure you already know this but here is a good resource deploy LabVIEW code modules in TestStand:
http://www.ni.com/white-paper/9923/en/
Jonathan R.
(3,859 Views)
