11-21-2014 03:45 AM
When I am trying to open the Import/Export Properties I get an System Level exception when the 'GenericImportExport.seq' is run.
The development machine is using windows 7 64 bit with Teststand 32 bit(latest version)
I can see in the sequence that it calls a .dll named TSDBComponents which causes it to fail.
I have tried the following:
Reinstallation and repair of Teststand
Reparing runtime engines of various sort (NI programs)
Good to know:
Was updated from Teststand 2013-->2014 recently.
When exiting Teststand some resources are not released:
References to PropertyObjects were not released properly. Total number of objects: 56 Number of top-level objects: 7 Note: Some top-level objects may be included if they are referenced by an incorrectly released top-level object. For example, an unreleased SequenceContext object references a SequenceFile object. The following top-level objects were not released: Type Definitions [3 object(s) not released] Type Definition #1: Name: DatabasePropertyMapping Type Definition #2: Name: DatabaseColumnValue Type Definition #3: Name: Expression PropertyObjects [4 object(s) not released] PropertyObject #1: Name: PropertiesList Type: Array of Containers PropertyObject #2: Name: ExtraInfo Type: Array of Containers PropertyObject #3: Name: PropertiesList Type: Array of Containers PropertyObject #4: Name: ExtraInfo Type: Array of Containers
From an previous post I saw that it was possible to get some more information regarding the exception with procdump, I dont know if this helps at all but here it is at least.
procdump.exe -g -e 1 -f c0000005 -x c:\dumpdir "C:\Program Files (x86)\National Instruments\TestStand 2014\Bin\seqedit.exe" [10:17:45] Exception: 04242420 [10:17:48] Exception: E06D7363.PAVEETypeLoadException@@ [10:17:48] Exception: E06D7363.msc [10:17:48] Exception: E06D7363.msc [10:17:48] Exception: E06D7363.msc [10:17:50] Exception: E06D7363.PAVEETypeLoadException@@ [10:17:50] Exception: E06D7363.msc [10:18:20] Exception: C0000005.ACCESS_VIOLATION
11-26-2014 05:41 AM
Hi mperss,
In regards with your Error Code have you looked at some of the troubleshooting options KnowledgeBase that are available. Please have a look and let me know if you are still seeing the error.
GajanS
