Hi There,
I am working under the constraints of a Source Code Control package (PVCS) - so would like to be able to check out sequences, VIs and configuration files to a particular directory (this name can vary based on the task, but there is only ever one check out directory at any one time). When opening TestStand or LabVIEW, files should first be picked up from here, and if they don't exist from a number of other fixed locations. I have fixed my search paths so that this works perfectly for sequences and VIs (set to search Initial Working Directory (in TS), then specific master directory. LabVIEW simply searches the current directory (since TS opens the top level VI in the right folder, and then the specific master directory) - NO PROBLEM SO FAR.
HOWEVER - this does not work for my custom type palette (INI file). It looks as though I can only specify a fixed location for this - so when I check it out to a new directory, TestStand sill picks up the "old" one. I don't want to have to go and keep changing the path every time I check out to a new directory or check back in -
IS THERE A WAY I CAN MAKE THIS RELATIVE?
Rich
