09-29-2005 02:48 AM
09-30-2005 10:28 AM
10-06-2005 02:01 AM
10-06-2005 10:08 AM
10-10-2005 03:20 AM
10-10-2005 10:01 AM
Carsten,
The debugging of an execution does not care what tracing options you have selected. The next step that executes after the execution of your code module is the Post-Step Callback. Tracing is a different concept than debugging. Even if you have tracing completely disabled, if you set a breakpoint, the code will stop at that point and give you full access to the sequence (including all engine callbacks).
Allen P.
NI
10-17-2005 02:18 AM
This is a common problem encountered by a lot of TestStand users. Test operators generally need to place breakpoints in their sequences in order to test, investigate or repair a d.u.t but they don't want to see the details of the sequences (pre-substeps, post-substeps, process models steps, etc...). The only solution available now is to build a custom runtime operator interface and with the low level functions of the Teststand API catch and filter the steps that will be displayed to the operator. This is a complicated task but there is no other solutions now because TestStand don't offer any standard mechanism to solve it.
10-17-2005 10:13 AM
10-20-2005 01:44 AM
