NI TestStand
Tracing doesn't work
when I put tracing enabled it behaves like it wasn't enabled. I'm using Teststand 3.1 with patch 3.1f1.
Tito Fidalgo
(3,059 Views)
Does the sequence execute normally?
 Do you use the sequence editor or the operator interface? Are you sure you do not disable Tracing dynamically in a sub sequence?
Benjamin M
NIF
(3,040 Views)
Yes the sequences runs normally. I'm using the sequence editor and i run the same sequence on another machine with the same setup and tracing works fine.
Tito Fidalgo
(3,037 Views)
your TS version seems corrupted. Indeed, it works fine on another computer. Maybe you should try reinstall TS and then check if the problem still occurs.
Benjamin M
NIF
(3,028 Views)
