NI TestStand
Timer expiry to cause sequence failure
I would like to cause a sequence to go to cleanup and the result to fail after a timer has expired.
At the moment in the 'Post Conditions' of the timers I have specified a custom condition expression: Step.Result.TimeoutOccured
On condition True: Go to Cleannup
On condition False: Go to next step.
How would it possible to modify the result to fail once the timer has expired?
Many thanks,
(2,447 Views)
Hi feb,
Just had a look around the forums.  Without a bit more information I'm not able to answer the question but maybe these posts will help you out?
Hope these help.
Is there any chance (if this doesn't help, you could forward on some of your code and I could have a closer look?)
AdamB
Applications Engineering Team Leader | National Instruments | UK & Ireland
(2,420 Views)
