02-17-2013 07:59 PM
Hello, all
I am new to teststand and just beginning to do some work with teststand.
My interest is to report every step with data begin with a time stamp.
I create subtest in the Numeric type property to report timestamp in the form of YYYY-MM-DD-HH-mm-ss
These substep are pre-step and post-step and in pre-step I get timestamp at the beginning and
post step I get a timestamp at the ens of the step.
Thing workout pretty well until I report a skip test.
A skip step does not run so a pre-step and post-step report a time stamp as 00000000000000.
how can I over come this problem since i want the skip test report as exact the same with "Normal Step"
is there any way to have a f(x) at the beginning and the end of the step type, and theses f(x) of course
should be execute even that step is skipped
TP
Solved! Go to Solution.
02-18-2013 04:31 PM
Hi TP,
Can you go into more detail about how the steps in TestStand get skipped?
02-18-2013 04:47 PM
I manually go to the setting page, run option tab and select run mode as skip.
The step does report in the test report data as skip but time stamp was all zero
02-18-2013 06:00 PM
The pre and post expression of skipped steps is never evaluated. I don't know of a way to time skipped steps using Pre or Post step callbacks unless you want to try and measure the elapsed execution time in the previous and next steps after the skipped step.
At the end of the day measuring the execution time of skipped steps is irrelevent because the amount of time they take to execute is essentially nothing. I just tried it using pre and post expressions in the previous and next steps relative to the skipped step and got 15 miliseconds with tracing turned on and 148 microseconds with tracing turned off.
02-18-2013 06:15 PM
Hello
For me that is important and for many thing I do the step carried out take a longtime than normal, especial if you test with around 20 socket and more.
I am surprised that a step type does not have some thing reserved for Pre-execution. This can help condition further a costumed step.
The only way I can poke in there may be using "precondition" to put my time stamp. But that mean my costumed model leaves a bunch of f(x) in there and look ugly
02-20-2013 02:33 PM
Found that under TS.StartTime. It just need a converter time stamp from teststand to local time
