Do you have timestamp enable on the logged results, to see if the systems were starting to run slow. (Thinking out aloud here). Its probably not running out memory because you probably would have seen some sort of windows warning. Its more likely, that a call has been made either in the test code or the OI and its decided not to return.
Do you know what the last logged result is, so as to try identify where in the test cycle the systems may be prior to the crash and hence what bit of hardware may have been communicated with?
* Test was running consistent all the way to the end (see attached log). The attached file is a .csv file but changed extenson to .txt because of error message, "The file does not have a valid extension for an attachment. jpg,gif,txt,xls,vi,zip,doc,bmp,llb,pdf,png,seq,c,h,cpp,cs,vb,ini,gz,ctl,scr,ico,tar,z,uir are the valid extensions.
" Average test time was 12 seconds. This is a game playing application so absolute time per test doesn't have as much meaning as a manufacturing test. Test system was running fine at time of the shutdown with nothing abnormal.
Have you tried running your test sequences using the SeqEditor rather than the OI. (Just trying to limit whether its the OI or the test code.)
* My development system has never crashed and completely exited. In the same note, it is my development system and typically only run overnight.
(You could run with the default OI which is at LV6.1 but set the LabVIEW Adapter to use the LV RTE7.1.)
* Tried to run the OI out of the box and caused much pain! System was locking up. Solved by NI tech support as needed to recompile operator interface after a week of debug.
Are you by any chance using the Volume Licensing Manager for your TestStand license? There was an issue with that could cause teststand to shutdown if it couldn't connect with the licensing manager. It was fixed in 3.1f1.
* Not using Volume License Manager. I am running 3.1 and not 3.1f1
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
