08-20-2013 04:48 AM
I try to access dll .NET method int myMethod ( string, string, string , ref object) and TestStand does not success to this accession.
I don't understand cause I call this with Parameters that have same type and ObjectReference corresponding to ref Object in the method
Solved! Go to Solution.
08-21-2013 01:53 PM
What errors are you getting? If you attach the visual studio debugger and attempt to step into the code do you see your code being called?
08-23-2013 03:17 AM
Its done. TestStand not recognized .Net Object from Dll return method.
