09-21-2005 03:15 AM
09-22-2005 02:57 PM
Billy,
You are correct, there is a version problem. In the TestStand directory there is a file:
Redist\lvruntimeeng71.msm
TestStand 3.1 ships the 7.1 version because 7.1.1 was not released when TestStand 3.1 released.
When you upgraded LabVIEW to 7.1.1, the LabVIEW file is updated but the TestStand file is not.
You can fix it by installing LabVIEW 7.1.1 renaming TestStand 3.1\Redist\lvruntimeeng71.msm
and then copying LabVIEW 7.1\applibs\distkit\redist\modules\lvruntime.msm to TestStand 3.1\Redist\lvruntimeeng71.msm
Note that the file names are different because TestStand supports installing several LabVIEW runtime engines. As you have discovered the LabVIEW 7.1.1 runtime engine can not co-exit with the LabVIEW 7.1 runtime engine.
-Rick Francis
11-11-2005 10:15 AM
Rick,
I am having a similiar problem. I get the same error message when I try opening Digital Waveform Editor. Is the solution the same? If it is the same, what do you rename TestStand 3.1\Redist\lvruntimeeng71.msm file to? And do you copy 7.1LabVIEW 7.1\applibs\distkit\redist\modules\lvruntime.msm to replace TestStand 3.1\Redist\lvruntimeeng71.msm or just put it with it?
Brian
11-11-2005 12:17 PM
Brian,
I suspect it is the same underlying problem, I suggested renaming the TestStand 3.1\Redist\lvruntimeeng71.msm file in case you ever need to have the 7.1.0 RTE. A good file name would be lvruntimeeng710.msm. Once the file is renamed copy LabVIEW 7.1\applibs\distkit\redist\modules\lvruntime.msm to TestStand 3.1\Redist\lvruntimeeng71.msm and rebuild the installer that included the TestStand engine. The new installer will include version 7.1.1 of the LabVIEW runtime engine. Uninstall the old installer and install the new installer. If the problem persists, post again and we can work on it further.
-Rick Francis
11-14-2005 09:07 AM
11-14-2005 11:14 AM
