NI TestStand
Teststand deployment error
I am getting the following error when I try to create my Teststand deployment files from my workspace:
Error Code:1035
Could not process LabVIEW VIs. Fix any broken VIs before rebuilding. LabVIEW error:
Invoke Node in TestStand - Dist Chg and Save VIs.vi->TestStand - Dist Build LLB Image.vi->TestStand - Build VI Distribution.vi->TestStand - Build VI Distribution AX Wrapper.vi->TestStand - Build VI Distribution AX Wrapper.vi.ProxyCaller
Anyone know what's happening here or how to fix the broken vi's this references?
(2,576 Views)
Check that all your VI's are Ok and that there are no broken arrows. One way would be to mas compile your LLB's/VI's that you are trying to deploy.
Regards
Ray Farmer
Regards
Ray Farmer
(2,570 Views)
