06-25-2012 07:27 AM
I use TestStand for creating test sequences. I am just curious to know that, is it possible to run TestStand using QTP scripts. Has someone tried this before? My purpose is to automate test sequence creation using QTP.
06-25-2012 08:01 AM
TestStand has an extensive ActiveX and/or .NET API. So if QTP can call through one of those then you should be good.
10-22-2012 03:05 PM
Hi AmitShah,
Were you able to build a TestStand sequence using QTP?
