05-28-2013 10:08 AM
I get the following message and error code when running my sequence file. This sequence files works ok on another machine. It is a display message to the screen for user input. Software version is 4.2.1
Teststand Sequence Editor has stopped working.
Problem signature:
Problem Event Name: CLR20r3
Problem Signature 01: seqedit.exe
Problem Signature 02: 4.2.1.83
Problem Signature 03: 4af027d1
Problem Signature 04: PresentationFramework
Problem Signature 05: 3.0.0.0
Problem Signature 06: 4f350630
Problem Signature 07: 6263
Problem Signature 08: e1
Problem Signature 09: System.Windows.Markup.XamlParse
OS Version: 6.1.7601.2.1.0.256.4
Locale ID: 1033
05-29-2013 02:03 AM
Does example sequences provided by TestStand (<TestStand/examples/>) run properly?
If yes, please give information on differences of those systems, e.g. OS (32/64bit), report settings, ...
Norbert
05-29-2013 10:15 AM - edited 05-29-2013 10:16 AM
Problem signature:
Locale ID: 1033
Do your code modules use System.Windows.Markup.XamlParse? Is the process close to running out of memory (i.e. over 1GB of memory used)? Do you have any DLLImprorts (if C#) or any native code (i.e. C/C++) being called by your sequences? Does the error happen every time you run? Always on the same step? If so, what is that step doing? Have you tried to debug the process?
-Doug
05-29-2013 10:33 AM
Doug,
The step that fails is in the process model and fails ever time. The steps is a call to a .NET module which is generically a user input dialog box. I do not have access to the source for the .NET dll. Memory is not an issue. I have verified the process model works on another computer and that my configuration seems to be the same as on the working computer.
05-30-2013 09:07 AM - edited 05-30-2013 09:10 AM
Does your .NET module perhaps require .NET 4 or newer, what version of .NET is it compiled for? If so you need a seqedit.config file specifying to use .NET 4.
Also, you might want to check Windows Update to see if there are some patches for the .NET framework that you haven't installed yet.
-Doug
