"Undefined symbol" means that you are using a variable/function which is defined in an external library ( that includes instrument drivers) , but you don't link that library to your code. In Labwindows/CVI you usually configure the linker to add a library by adding the function panel of the library/instrument to the project. In your example it seems that you need to add the Teststand API function panel to you project.
