I am new to TestStand and LabView. I am trying to call a VI module from TestStand. When I specify the module, and edit the LabView VI call, I set values for the input controls that I want to use for the call, the other inputs I left blank, . . . but when I click the [OK] button to save/close the module call I get a TestStand Warning:
Syntax Error in value for parameter ParameterName:
You must specify values for required parameters.
This value will cause a run-time error.
If I set a value for ParameterName, I get another warning for ParameterName2, and I assume this would continue until I specified a value for every input.
I checked the VI, and the inputs are all set to the default value of "Recommended". Why does TestStand insist that the values are "required"
