12-20-2005 12:40 AM
12-20-2005 12:57 AM
What is this your custom step doing? Is it always the same step?
Is it possible to run in a debug mode so that if it stop you could pause an see where in your code you are. If thats not possible, maybe you add some well placed text messages that aresent to a file or standard io window to give an indication where in the code you are.
Are you sure you are running the same code on this machice as the other. Scan for all occurances of dll's etc to ensure you are not using a debug version. If you are not sure, uninstall your code, executables, dlls and delete any files/folders that are haven't been removed by the uninstall process. Then start again from a know build.
Hope this helps
Regards
Ray Farmer
12-20-2005 05:33 AM
12-20-2005 07:40 AM
Hi daarya,
curious
Is the front panel meant to be displayed, other wise way do you need "NotifyStartOfModalDialogEx" method?
Is they an EndOfModalDialogEx method being used as well?
Regards
Ray Farmer
12-20-2005 02:16 PM
