Hello there,
I try to build a UI in TestStand 3.1 and LabView 7.1. I don't want to use Application-, Execution and SequenceView- Manager because you must use the SequenceView-Control to display some Details of Execution..
While executing a Sequencefile I want to show StepName, StepIndex.. on Front Panel with normal String- or Numeric-indicators.
To get a high Execution-Speed I don't use MessagePolling and create a UIMessageEvent-Callback-VI.
At first I tried to update my Indicators by using the References of it. But the UI hangs by trying to open a VI-Reference per Path. Open a VI-Reference by String works, but sometimes it hangs by closing this Reference. This effect occurred at my PC (Pentium 4 2,8 GHz 1GB Ram) after 20 minutes up to 9 hours. At a Pentium (Hyper-Threading) 3,2 Ghz, 512 MB Ram it hangs after a view minutes. On an old Pentium (200Mhz, 256KB) it works fine for a Week!?
So I changed the updating Indicators to Global Variables, with the same effect.
At last I removed all these to run a Sequencefile without any information about the status of the execution and again the UI hangs.
So I don't know what to do... What's Wrong?.
Please answer me.
Best Regards TPoint!
Message Edited by TPoint on 04-14-2005 04:09 AM
