The TestStand Reference manual provides good information on system
distribution. Chapter 14 : Deploying TestStand Systems covers the
necessary information for distributing your TestStand
application. I do have a few suggestions and caveats:
(1) Make sure you use a Work Space when distributing your
files. A Work Space makes it easy to package all of your files
and dependencies. Moreover, the distribution wizard provides a
feature that displays all the files that will be included in the
installation package into an easy to use Tree View.
(2) TestStand currently does not look for embedded DLL
dependencies. So, if your code is calling a DLL module that calls
a DLL module, be sure to include the embedded dependency DLL in your
WorkSpace.
(3) StationGlobals and Custom Data Types are usually missed in
installation. Be sure that you are including your
StationGlobals.ini file and MyTypes.ini file from the Cfg directory
into your installation workspace.
If you have more specific questions, please feel free to post them here!
Good Luck!
Tyler Tigue
