Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
04-10-2013 08:38 AM
I would like to know if the adapter java is available for TestStand 4.2 ?
If yes, how to install it ?
Thanks for your help
Patrick
04-11-2013 09:20 AM
There is no java adapter but you can interface Java with TestStand
With the link below, we can see you are able to call Java step type with Teststand 3.0. So you should be able to to the same with Teststand 4.2.
http://digital.ni.com/public.nsf/allkb/557C26504F9290388625734800678D37?OpenDocument
And please refer to this link (there is an exemple in TestStand With Java Step Type)
http://zone.ni.com/reference/en-XX/help/370052H-01/tssuppref/infotopics/java_steps/ (TestStand 4.2)
http://zone.ni.com/reference/en-XX/help/370052K-01/tssuppref/infotopics/java_steps/ (TestStand 12.0)
I hope it helps,
MatthieuR
Matthieu RICORDNational Instruments France
Été de LabVIEW 2014 12 présentations en ligne, du 30 juin au 18 juillet
Thanks!
We'll be in touch soon!
