NI TestStand
TestStand Using LabVIEW OOP Truck Example
This example uses TestStand 2012 and LabVIEW 2012 to demonstrate calling a LabVIEW VIs through dynamic dispatching.
The LabVIEW OOP example included ships with 2012 and can be found in: C:\Program Files\National Instruments\LabVIEW 2012\examples\lvoop\DynamicDispatching
In this example the Call OOP LabVIEW.seq will call the "Get Cargo Capacity.vi" in Vehicle passing both a Vehicle object and a Truck object to show the same behavior.
Running with Single pass a successful run will give you the following output:
"Truck1CargoCapacity = 1, Truck2CargoCapacity= 2, Vehicle3CargoCapacity = 3."
(10,356 Views)
hi,
can you downgrade this example so it can be use for TestStand 4.5.0 and Labview 8.5.1?
(4,247 Views)
TestStand 2012 is the first version of TestStand to support the required Dynamic Dispatch, so you're unfortunately not going to be able to get this in those older versions
(4,247 Views)
Hi Shew82,
is there any other example about Labview OOP usage in TestStand enviroment?
I already search around the web but there is none other than this example.
(4,247 Views)
very nice example....labview oop and testand running together....
CLAD, CTD
(4,231 Views)
