04-28-2013 07:58 PM
All,
I'm trying to verify if the TestStand Simple OI (LabVIEW) unloads a sequence when a new sequence is selected to run, I'm fairly new to TestStand interfacing with LabVIEW and I just want to verify, somehow, that there are not multiples sequences loaded at the same time; would anyone be able to help me out?
-Bill
04-29-2013 08:20 AM
Bill,
If it shows up in the drop down then it is open. So just opening a new one does not close the previous one. You have to explicitly click the Close Sequence File button. Or you can change the simple OI to handle this when a new one is opened.
However, opening a new sequence file does make the new one the "current" sequence file... i.e. it is selected.
I did verify that they are both opened by putting a property node on the application manager and getting the sequence files reference then using another property node to get the count. It returned that both sequence files were indeed open.
