Hi Buzz,
Here's an example I was using awhile back to demonstate a problem. But it might help you in your solution.
The example starts a dialog panel in a new execution. The MainSequence carries on and does something else.
The user has the option to press the button on the dialog to close the new execution, or the mainsequence will come to an end then terminates the new execution.
Hope it helps
Regards
Ray Farmer
Regards
Ray Farmer
