One option that I recommend is simply do not install the sequence editor on your deployment machine. In most situations, TestStand sequences are run from an operator interface on deployment machines so the sequence editor is usually not necessary.
To not include the TestStand sequence editor, go to the Installer Options tab of the TestStand Deployment Utility and click on the Engine Options button. Once there, you should see a check box to include the sequence editor under the Development System section. I would make sure the check box for the sequence editor is not selected.
I hope that this information helps you out.
Kevin L.
